Junction conditions for finite horizon optimal control problems on multi-domains with continuous and discontinuous solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2018
This paper deals with junction conditions for Hamilton-Jacobi-Bellman (HJB) equations for finite horizon control problems on multi-domains. We consider two different cases where the final cost is continuous or lower semi-continuous. In the continuous case we extend the results in [26] in a more general framework with switching running costs and weaker controllability assumptions. The comparison principle has been established to guarantee the uniqueness and the stability results for the HJB system on such multi-domains. In the lower semi-continuous case, we characterize the value function as the unique lower semi-continuous viscosity solution of the HJB system, under a local controllability assumption.
GRZpreprint.pdf (610.42 Ko) Télécharger le fichier
hal-01517505 , version 1 (03-05-2017)
Daria Ghilli, Zhiping Rao, Hasnaa Zidani. Junction conditions for finite horizon optimal control problems on multi-domains with continuous and discontinuous solutions. ESAIM: Control, Optimisation and Calculus of Variations, 2018, ⟨10.1051/cocv/2018072⟩. ⟨hal-01517505⟩
207 Consultations
194 Téléchargements
