Vision-Based Minimum-Time Trajectory Generation for a Quadrotor UAV - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we address the problem of using a camera with limited field of view for controlling the motion of a quadrotor in aggressive flight regimes. We present a minimum time trajectory planning method that guarantees visibility of the image features while allowing the robot to undertake aggressive motions for which the usual near-hovering assumption is violated. We exploit differential flatness and B-Splines to parametrize the system trajectories in terms of a finite number of control points, which can then be optimized by Sequential Quadratic Programming (SQP). The control strategy is similar to a Receding Horizon Control (RHC) approach for modifying online the reference trajectory in order to account for noise, disturbances and any non-modeled effect. The algorithm is validated in a physically realistic simulation environment.
2017_iros_penin.pdf (3.92 Mo) Télécharger le fichier
hal-01572362 , version 1 (07-08-2017)
  • HAL Id : hal-01572362 , version 1
Bryan Penin, Riccardo Spica, Paolo Robuffo Giordano, François Chaumette. Vision-Based Minimum-Time Trajectory Generation for a Quadrotor UAV. IROS 2017 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Sep 2017, Vancouver, Canada. pp.6199-6206. ⟨hal-01572362⟩
513 Consultations
841 Téléchargements
