A variational method for dejittering large fluorescence line scanner images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computational Imaging Année : 2018
We propose a variational method dedicated to jitter correction of large fluorescence scanner images. Our method consists in minimizing a global energy functional to estimate a dense displacement field representing the spatially-varying jitter. The computational approach is based on a half-quadratic splitting of the energy functional, which decouples the realignment data term and the dedicated differential-based regularizer. The resulting problem amounts to alternatively solving two convex and nonconvex optimization subproblems with appropriate algorithms. Experimental results on artificial and large real fluorescence images demonstrate that our method is not only capable to handle large displacements but is also efficient in terms of subpixel precision without inducing additional intensity artifacts.
HAL-dejittering.pdf (8.44 Mo) Télécharger le fichier
hal-01577139 , version 1 (24-08-2017)
  • HAL Id : hal-01577139 , version 1
Hoaï-Nam Nguyen, Vincent Paveau, Cyril Cauchois, Charles Kervrann. A variational method for dejittering large fluorescence line scanner images. IEEE Transactions on Computational Imaging, 2018, 4 (2), pp.16. ⟨hal-01577139⟩
Collections
INRIA INRIA2
234 Consultations
231 Téléchargements
