Active vision for pose estimation applied to singularity avoidance in visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In active vision, the camera motion is controlled in order to improve a certain visual sensing strategy. In this paper, we formulate an active vision task function to improve pose estimation. This is done by defining an optimality metric on the Fisher Information Matrix. This task is then incorporated into a weighted multi-objective optimization framework. To test this approach, we apply it on the three image point visual servoing problem which has a degenerate configuration-a singularity cylinder. The simulation results show that the singular configurations of pose estimation are avoided during visual servoing. We then discuss the potential of active vision to be integrated into more complex multi-task frameworks.
2017_iros_agravante.pdf (473.46 Ko) Télécharger le fichier
hal-01589882 , version 1 (19-09-2017)
  • HAL Id : hal-01589882 , version 1
Don Joven Agravante, François Chaumette. Active vision for pose estimation applied to singularity avoidance in visual servoing. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'17, Sep 2017, Vancouver, Canada. pp.2947-2952. ⟨hal-01589882⟩
235 Consultations
330 Téléchargements
