Singular mean-field control games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Analysis and Applications Année : 2017
This article studies singular mean field control problems and singular mean field two-players stochastic differential games. Both sufficient and necessary conditions for the optimal controls and for the Nash equilibrium are obtained. Under some assumptions the optimality conditions for singular mean-field control are reduced to a reflected Skorohod problem, whose solution is proved to exist uniquely. Motivations are given as optimal harvesting of stochastic mean-field systems, optimal irreversible investments under uncertainty and mean-field singular investment games. In particular, a simple singular mean-field investment game is studied, where the Nash equilibrium exists but is not unique.
[HOS]28April2017MeanfieldSingGames.pdf (352.34 Ko) Télécharger le fichier
hal-01614747 , version 1 (18-10-2017)
Yaozhong Hu, Bernt Øksendal, Agnès Sulem. Singular mean-field control games. Stochastic Analysis and Applications, 2017, 35 (5), pp.823-851. ⟨10.1080/07362994.2017.1325745⟩. ⟨hal-01614747⟩
345 Consultations
485 Téléchargements
