CompCert: Practical Experience on Integrating and Qualifying a Formally Verified Optimizing Compiler - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
CompCert is the first commercially available optimizing compiler that is formally verified, using machine-assisted mathematical proofs, to be exempt from mis-compilation. The executable code it produces is proved to behave exactly as specified by the semantics of the source C program. This article gives an overview of the use of CompCert to gain certification credits for a highly safety-critical industry application, certified according to IEC 60880. We will briefly introduce the target application, illustrate the process of changing the existing compiler infrastructure to CompCert, and discuss performance characteristics. The main part focuses on the tool qualification strategy, in particular on how to take advantage of the formal correctness proof in the certification process.
ERTS_2018_paper_59.pdf (264.76 Ko) Télécharger le fichier
hal-01643290 , version 1 (21-11-2017)
  • HAL Id : hal-01643290 , version 1
Daniel Kästner, Jörg Barrho, Ulrich Wünsche, Marc Schlickling, Bernhard Schommer, et al.. CompCert: Practical Experience on Integrating and Qualifying a Formally Verified Optimizing Compiler. ERTS2 2018 - 9th European Congress Embedded Real-Time Software and Systems, 3AF, SEE, SIE, Jan 2018, Toulouse, France. pp.1-9. ⟨hal-01643290⟩
3831 Consultations
2007 Téléchargements
