Gröbner bases over Tate algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tate algebras are fundamental objects in the context of analytic geometry over the p-adics. Roughly speaking, they play the same role as polynomial algebras play in classical algebraic geometry. In the present article, we develop the formalism of Gröbner bases for Tate algebras. We prove an analogue of the Buchberger criterion in our framework and design a Buchberger-like and a F4-like algorithm for computing Gröbner bases over Tate algebras. An implementation in SM is also discussed.
tate_algebra_acm.pdf (245.77 Ko) Télécharger le fichier
hal-01995881 , version 1 (27-01-2019)
hal-01995881 , version 2 (06-05-2019)
Xavier Caruso, Tristan Vaccon, Thibaut Verron. Gröbner bases over Tate algebras. ISSAC 2019 - International Symposium on Symbolic and Algebraic Computation, Jul 2019, Beijing, China. ⟨10.1145/3326229.3326257⟩. ⟨hal-01995881v2⟩
156 Consultations
219 Téléchargements
