Abstract Simulation of Reaction Networks via Boolean Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose to simulate chemical reaction networks with the deterministic semantics abstractly, without any precise knowledge on the initial concentrations. For this, the concentrations of species are abstracted to Booleans stating whether the species is present or absent, and the derivatives of the concentrations are abstracted to signs saying whether the concentration is increasing, decreasing, or unchanged. We use abstract interpretation over the structure of signs for mapping the ODEs of a reaction network to a Boolean network with nondeterministic updates. The abstract state transition graph of such Boolean networks can be computed by finite domain constraint programming over the finite structure of signs. Constraints on the abstraction of the initial concentrations can be added naturally, leading to an abstract simulation algorithm that produces only the part of the abstract state transition graph that is reachable from the abstraction of the initial state. We prove the soundness of our abstract simulation algorithm, discuss its implementation, and show its applicability to reaction networks in the SBML format from the BioModels database.
1.pdf (1.54 Mo) Télécharger le fichier
hal-02279942 , version 1 (13-05-2020)
hal-02279942 , version 2 (15-05-2020)
hal-02279942 , version 3 (07-05-2021)
hal-02279942 , version 4 (11-05-2021)
hal-02279942 , version 5 (12-05-2021)
hal-02279942 , version 6 (26-07-2021)
hal-02279942 , version 7 (15-09-2021)
hal-02279942 , version 8 (17-05-2022)
hal-02279942 , version 9 (24-06-2022)
  • HAL Id : hal-02279942 , version 9
Joachim Niehren, Athénaïs Vaginay, Cristian Versari. Abstract Simulation of Reaction Networks via Boolean Networks. CMSB 2022 - 20th International Conference on Computational Methods in Systems Biology, Sep 2022, Bucarest, Romania. ⟨hal-02279942v9⟩
574 Consultations
373 Téléchargements
