The Hoare-fol Tool
This document presents the tool named "Application of Hoare Logic and Dijkstra's Weakest Proposition Calculus to Biological Regulatory Networks Using Path Programs with Branching First-Order Logic Operators" or Hoare-fol for short. This tool consists in an implementation of the theoretical work developed in [Bernot et al., 2019] and contains the following features: (1) computation of the weakest precondition of a Hoare triple, (2) simplification of this weakest precondition using De Morgan laws and partial knowledge on the initial state, and (3) translation into Answer Set Programming to allow a solving of all compatible solutions.
