A mixed finite element discretization of dynamical optimal transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2022
In this paper we introduce a new class of finite element discretizations of the quadratic optimal transport problem based on its dynamical formulation. These generalize to the finite element setting the finite difference scheme proposed by Papadakis et al. [SIAM J Imaging Sci, 7(1):212–238,2014]. We solve the discrete problem using a proximal splitting approach and we show how to modify this in the presence of regularization terms which are relevant for physical data interpolation.
MixedFiniteElementsHAL.pdf (1.93 Mo) Télécharger le fichier
hal-02501634 , version 1 (09-03-2020)
hal-02501634 , version 2 (22-05-2020)
hal-02501634 , version 3 (12-10-2020)
hal-02501634 , version 4 (22-02-2022)
Andrea Natale, Gabriele Todeschi. A mixed finite element discretization of dynamical optimal transport. Journal of Scientific Computing, In press, ⟨10.1007/s10915-022-01821-y⟩. ⟨hal-02501634v4⟩
348 Consultations
189 Téléchargements
