Fast computation of hyperelliptic curve isogenies in odd characteristic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Let p be an odd prime number and g ≥ 2 be an integer. We present an algorithm for computing explicit rational representations of isogenies between Jacobians of hyperelliptic curves of genus g over an extension K of the field of p-adic numbers Qp. It relies on an efficient resolution, with a logarithmic loss of p-adic precision, of a first order system of differential equations.
ArticleSup.pdf (554.46 Ko) Télécharger le fichier
hal-02948514 , version 1 (24-09-2020)
  • HAL Id : hal-02948514 , version 1
Elie Eid. Fast computation of hyperelliptic curve isogenies in odd characteristic. International Symposium on Symbolic and Algebraic Computation — ISSAC 2021, Jul 2021, Virtual event, Russia. pp.131-138. ⟨hal-02948514⟩
134 Consultations
71 Téléchargements
