Linear representation of endomorphisms of Kummer varieties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Let K A be a Kummer variety defined as the quotient of an Abelian variety A by the automorphism (−1) of A. Let T * 0 (A) be the co-tangent space at the point 0 of A. Let End(A) be the additive group of endomorphisms of A. There is a well defined map ρ : End(A) → Aut(T * 0 (A)), f → (df) * 0 , where (df) * 0 is the differential of f in 0 acting on T * 0 (A). The data of f ∈ End(K A) which comes from f ∈ End(A), determines ρ(f) up to a sign. The aim of this paper is to describe an efficient algorithm to recover ρ(f) up to a sign from the knowledge of f. Our algorithm is based on a study of the tangent cone of a Kummer variety in its singular 0 point. We give an application to Mestre's point counting algorithm.
action.pdf (636.27 Ko) Télécharger le fichier
hal-03204365 , version 1 (21-04-2021)
  • HAL Id : hal-03204365 , version 1
David Lubicz, Damien Robert. Linear representation of endomorphisms of Kummer varieties. 2021. ⟨hal-03204365⟩
167 Consultations
73 Téléchargements
