Multiboost: a multi-purpose boosting package - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2012
The MultiBoost package provides a fast C++ implementation of multi-class/multi-label/multi-task boosting algorithms. It is based on AdaBoost.MH but it also implements popular cascade classifiers and FilterBoost. The package contains common multi-class base learners (stumps, trees, products, Haar filters). Further base learners and strong learners following the boosting paradigm can be easily implemented in a flexible framework.
Multiboost.pdf (99.62 Ko) Télécharger le fichier
in2p3-00698455 , version 1 (21-05-2012)
  • HAL Id : in2p3-00698455 , version 1
D. Benbouzid, Róbert Busa-Fekete, N. Casagrande, F.-D. Collin, Balázs Kégl. Multiboost: a multi-purpose boosting package. Journal of Machine Learning Research, 2012, 13, pp.549-553. ⟨in2p3-00698455⟩
90 Consultations
383 Téléchargements
