Fast classification using sparse decision DAGs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we propose an algorithm that builds sparse decision DAGs (directed acyclic graphs) out of a list of base classifiers provided by an external learning method such as AdaBoost. The basic idea is to cast the DAG design task as a Markov decision process. Each instance can decide to use or to skip each base classifier, based on the current state of the classifier being built. The result is a sparse decision DAG where the base classifiers are selected in a data-dependent way. The method has a single hyperparameter with a clear semantics of controlling the accuracy/speed trade-off. The algorithm is competitive with state-of-the-art cascade detectors on three object-detection benchmarks, and it clearly outperforms them in the regime of low number of base classifiers. Unlike cascades, it is also readily applicable for multi-class classification. Using the multi-class setup, we show on a benchmark web page ranking data set that we can significantly improve the decision speed without harming the performance of the ranker.
Fast_classification.pdf (400.5 Ko) Télécharger le fichier
in2p3-00711150 , version 1 (22-06-2012)
  • HAL Id : in2p3-00711150 , version 1
Róbert Busa-Fekete, D. Benbouzid, Balázs Kégl. Fast classification using sparse decision DAGs. 29th International Conference on Machine Learning (ICML 2012), Jun 2012, Edinburgh, United Kingdom. pp.951-958. ⟨in2p3-00711150⟩
143 Consultations
73 Téléchargements
