The necessity of optimal design for parallel machines and a possible certified methodology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Although they have many advantages in term of positioning accuracy, stiffness, load capacity parallel machines have also a main drawback: their performances are very sensitive to their dimensioning. Hence although the choice of a given mechanical structure among the numerous possibilities that are offered for parallel machines may influence the performances of the machine the rule of thumb is: a mechanically appropriate but poorly dimensioned machine will present in general largely lower performances than a well designed machine with a mechanical architecture a priori less adequate. Optimal dimensioning of a parallel machine is hence a critical issue but also a complex one, especially if uncertainties in the manufacturing are taken into account. We will present a possible design methodology based on interval analysis and will illustrate this methodology on realistic examples.
braunschweig2005-paper.pdf (149.1 Ko) Télécharger le fichier
inria-00000008 , version 1 (07-05-2005)
  • HAL Id : inria-00000008 , version 1
Jean-Pierre Merlet. The necessity of optimal design for parallel machines and a possible certified methodology. Robotic Systems for Handling and Assembly, SFB 562, May 2005, Braunschweig. ⟨inria-00000008⟩
77 Consultations
35 Téléchargements
