Characterizing Self-Developing Biological Neural Networks: A First Step Towards their Application To Computing Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Lecture Notes in Computer Science Année : 2005
Carbon nanotubes are often seen as the only alternative technology to silicon transistors. While they are the most likely short-term one, other longer-term alternatives should be studied as well. While contemplating biological neurons as an alternative component may seem preposterous at first sight, significant recent progress in CMOS-neuron interface suggests this direction may not be unrealistic; moreover, biological neurons are known to self-assemble into very large networks capable of complex information processing tasks, something that has yet to be achieved with other emerging technologies. The first step to designing computing systems on top of biological neurons is to build an abstract model of self-assembled biological neural networks, much like computer architects manipulate abstract models of transistors and circuits. In this article, we propose a first model of the structure of biological neural networks. We provide empirical evidence that this model matches the biological neural networks found in living
organisms, and exhibits the small-world graph structure properties
commonly found in many large and self-organized systems, including
biological neural networks. More importantly, we extract the simple
local rules and characteristics governing the growth of such networks, enabling the development of potentially large but realistic biological neural networks, as would be needed for complex information processing/computing tasks. Based on this model, future work will be targeted to understanding the evolution and learning properties of such networks, and how they can be used to build computing systems.
BerryTemamLNCS2005.pdf (322.68 Ko) Télécharger le fichier
inria-00000024 , version 1 (10-05-2005)
Hugues Berry, Olivier Temam. Characterizing Self-Developing Biological Neural Networks: A First Step Towards their Application To Computing Systems. Lecture Notes in Computer Science, 2005, 3512, pp.306-317. ⟨inria-00000024⟩
279 Consultations
354 Téléchargements
