Implementation of ARTiS, an Asymmetric Real-Time Extension of SMP Linux - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
ARTiS is a real-time extension of GNU/Linux dedicated to SMP systems (Symmetric Multi-Processors). ARTiS divides the CPUs of an SMP system into two sets: real-time CPUs and non real-time CPUs. Real-time CPUs execute preemptible code only, thus tasks running on these processors perform predictably. If a task wants to enter into a non-preemptible section of code on a real-time processor, ARTiS will automatically migrate this task to a non real-time processor. Furthermore, dedicated load-balancing strategies allow all the system's CPUs to be fully exploited. \par The purpose of this paper is to describe the basic API that has been specified to deploy real-time applications, and to present the current implementation of the ARTiS model, which was achieved through modifications of the 2.6 Linux kernel. The implementation is build around an automatic migration of tasks between real-time and non real-time processors and the use of a load-balancer. The basic function of those mechanisms is to move a task structure from one processor to another. A strong constraint of the implementation is the impossibility for the code running on an RT processor to share a lock or to wait after another processor.
paper.pdf (152.28 Ko) Télécharger le fichier
inria-00000140 , version 1 (21-11-2005)
  • HAL Id : inria-00000140 , version 1
Philippe Marquet, Éric Piel, Julien Soula, Jean-Luc Dekeyser. Implementation of ARTiS, an Asymmetric Real-Time Extension of SMP Linux. Sixth Realtime Linux Workshop, Nov 2004, Singapore. ⟨inria-00000140⟩
118 Consultations
181 Téléchargements
