Users and Assessors in the Context of INEX: Are Relevance Dimensions Relevant? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
The main aspects of XML retrieval are identified by analysing and comparing the following two behaviours: the behaviour of the assessor when judging the relevance of returned document components; and the behaviour of users when interacting with components of XML documents. We argue that the two INEX relevance dimensions, Exhaustivity and Specificity, are not orthogonal dimensions; indeed, an empirical analysis of each dimension reveals that the grades of the two dimensions are correlated to each other. By analysing the level of agreement between the assessor and the users, we aim at identifying the best units of retrieval. The results of our analysis show that the highest level of agreement is on highly relevant and on non-relevant document components, suggesting that only the end points of the INEX 10-point relevance scale are perceived in the same way by both the assessor and the users. We propose a new definition of relevance for XML retrieval and argue that its corresponding relevance scale would be a better choice for INEX.
jovanp.pdf (246.18 Ko) Télécharger le fichier
INEX05-methodology-talk.ppt (508 Ko) Télécharger le fichier
Format : Autre
inria-00000182 , version 1 (28-07-2005)
Jovan Pehcevski, James A. Thom, Anne-Marie Vercoustre. Users and Assessors in the Context of INEX: Are Relevance Dimensions Relevant?. INEX 2005 Workshop on Element Retrieval Methodology, University of Glasgow, Jul 2005, Glasgow, Scotland. ⟨inria-00000182⟩
Collections
INRIA INRIA2
80 Consultations
91 Téléchargements
