Developing a Software Tool for Precise Kernel Measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Tracing the flow of control in a running kernel is useful for determining where performance can be improved, for instance. FKT (Fast Kernel Tracing) is a set of tools to achieve such tracing. However, its recording size was limited to the size of available memory, lacking a flushing mechanism. We here describe how such flushing was added to FKT without too much perturbing the measurements, how new issues raised by long recordings were addressed, as well as the new features that became useful.
RR-5602.pdf (225.07 Ko) Télécharger le fichier
report.pdf (212.92 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00000189 , version 1 (05-08-2005)
inria-00000189 , version 2 (05-12-2006)
  • HAL Id : inria-00000189 , version 2
Samuel Thibault, Robert Russell. Developing a Software Tool for Precise Kernel Measurements. [Research Report] RR-5602, INRIA. 2005, pp.25. ⟨inria-00000189v2⟩
202 Consultations
192 Téléchargements
