Permutation flowshops with exact time lags to minimize maximum lateness - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
In this paper, we investigate the m-machine permutation flowshop scheduling problem where exact time lags are defined between consecutive operations of every job. The objective is to minimize the maximum lateness. We introduce different job types, depending on their time lags. We study polynomial special cases and provide a dominance relation. We derive lower and upper bounds that are integrated in a branch-and-bound procedure to solve the problem. We perform a computational analysis to evaluate the efficiency of the proposed method.
rr_inria.pdf (349.76 Ko) Télécharger le fichier
inria-00000190 , version 1 (09-08-2005)
  • HAL Id : inria-00000190 , version 1
Julien Fondrevelle, Ali Allahverdi, Ammar Oulamara, Marie-Claude Portmann. Permutation flowshops with exact time lags to minimize maximum lateness. [Intern report] 2005, pp.18. ⟨inria-00000190⟩
74 Consultations
46 Téléchargements
