s'authentifier
version française rss feed
inria-00000201, version 1
Spectral theorem for convex monotone homogeneous maps, and ergodic control
Marianne Akian () 1, Stéphane Gaubert () 1
Nonlinear Analysis Theory Methods and Applications 52, 2 (2003) 637-679
Résumé : We consider convex maps f:R^n -> R^n that are monotone (i.e., that preserve the product ordering of R^n), and nonexpansive for the sup-norm. This includes convex monotone maps that are additively homogeneous (i.e., that commute with the addition of constants). We show that the fixed point set of f, when it is non-empty, is isomorphic to a convex inf-subsemilattice of R^n, whose dimension is at most equal to the number of strongly connected components of a critical graph defined from the tangent affine maps of f. This yields in particular an uniqueness result for the bias vector of ergodic control problems. This generalizes results obtained previously by Lanery, Romanovsky, and Schweitzer and Federgruen, for ergodic control problems with finite state and action spaces, which correspond to the special case of piecewise affine maps f. We also show that the length of periodic orbits of f is bounded by the cyclicity of its critical graph, which implies that the possible orbit lengths of f are exactly the orders of elements of the symmetric group on n letters.
  • Domaine : Mathématiques/Optimisation et contrôle
    Mathématiques/Théorie spectrale
  • Mots-clés : Nonexpansive maps – Periodic orbits – Eigenspace – Spectral theorem – Stochastic Control – Ergodic Control – Perron-Frobenius Theorem – Max-plus algebra – Critical graph – Convexity – Subdifferentials
  • Commentaire : Preliminary version in http://arXiv.org/abs/math.SP/0110108 and in the INRIA research report 4273 (http://www.inria.fr/rrrt/rr-4273.html)./http://www.sciencedirect.com/science/journal/0362546X
  • inria-00000201, version 1
  • oai:hal.inria.fr:inria-00000201
  • Contributeur :
  • Soumis le : Lundi 12 Septembre 2005, 18:30:32
  • Dernière modification le : Mardi 13 Septembre 2005, 16:32:41
tous les articles de la base du CCSd...
