Scilab to Scilab//, the OURAGAN Project - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Computing Année : 2001
Eddy Caron
Martin Quinson
Frédéric Suter
Gil Utard
In this paper, we present the developments realized in the "Ouragan" project around the parallelization of a "Matlab"-like tool called "SCILAB". These developments use high-performance numerical libraries and different approaches based either on the duplication of "SCILAB" processes or on computational servers. This tool, "SCILAB", allows users to perform high-level operations on distributed matrices in a metacomputing environment. We also present performance results on different architectures.
inria-00000277 , version 1 (21-09-2005)
Eddy Caron, Serge Chaumette, Sylvain Contassot-Vivier, Frédéric Desprez, Eric Fleury, et al.. Scilab to Scilab//, the OURAGAN Project. Parallel Computing, 2001, 27 (11), pp.1497-1519. ⟨10.1016/S0167-8191(01)00101-6⟩. ⟨inria-00000277⟩
405 Consultations
0 Téléchargements
