inria-00000839, version 2
A Flexible Structured-based Representation for XML Document Mining
Anne-Marie Vercoustre
a, 1Mounir Fegas a, 1Saba Gul a, 1Yves Lechevallier
a, 1
The Fourth International Workshop of the Initiative for the Evaluation of XML Retrieval (INEX 2005) Volume 3977 / 2006/3-540-34962-6 (2005) pp. 443 - 457
Résumé : This paper reports on the INRIA group's approach to XML mining while participating in the INEX XML Mining track 2005. We use a flexible representation of XML documents that allows taking into account the structure only or both the structure and content. Our approach consists of representing XML documents by a set of their sub-paths, defined according to some criteria (length, root beginning, leaf ending). By considering those sub-paths as words, we can use standard methods for vocabulary reduction, and simple clustering methods such as K-means that scale well. We actually use an implementation of the clustering algorithm known as "dynamic clouds" that can work with distinct groups of independent variables put in separate variables. This is useful in our model since embedded sub-paths are not independent: we split potentially dependant paths into separate variables, resulting in each of them containing independant paths. Experiments with the INEX collections show good results for the structure-only collections, but our approach could not scale well for large structure-and-content collections.
- a – INRIA
- 1 : AxIS (INRIA Rocquencourt / INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Recherche d'information
- Mots-clés : XML – Clustering – Document model – Document mining
- Commentaire : This is the authors' version. To access the final version go to the editor's site through the DOI./http://www.springerlink.com
- Versions disponibles : v1 (23-11-2005) v2 (05-07-2006)
- inria-00000839, version 2
- http://hal.inria.fr/inria-00000839
- oai:hal.inria.fr:inria-00000839
- Contributeur : Anne-Marie Vercoustre
- Soumis le : Mercredi 5 Juillet 2006, 12:08:44
- Dernière modification le : Vendredi 28 Juillet 2006, 15:49:51
Documents associés
Exporter
