s'authentifier
version française rss feed
inria-00000874, version 1
Network Coding forWireless Mesh Networks: A Case Study
Anwar Al Hamra a1, Chadi Barakat () 2, Thierry Turletti () 2
(2006)
Résumé : Network coding is a new transmission paradigm that proved its strength in optimizing the usage of network resources. In this paper, we evaluate the gain from using network coding for file sharing applications running on top of wireless mesh networks. With extensive simulations carried out on a simulator we developed specifically for this study, we confirm that network coding can improve the performance of the file sharing application, but not as in wired networks. The main reason is that nodes over wireless cannot listen to different neighbors simultaneously. Nevertheless, one can get more from network coding if the information transmission is made more diverse inside the network. We support this argument by varying the loss rate over wireless links and adding more sources.
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : Wireless Mesh Networks – Ad Hoc Networks – Network Coding – File Sharing
  • inria-00000874, version 1
  • oai:hal.inria.fr:inria-00000874
  • Contributeur :
  • Soumis le : Mardi 29 Novembre 2005, 14:36:25
  • Dernière modification le : Mardi 30 Septembre 2008, 13:36:58
tous les articles de la base du CCSd...
