Efficient Sampling of Random Permutations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Discrete Algorithms Année : 2008
Jens Gustedt
We show how to uniformly distribute data at random (not to be confounded with permutation routing) in two settings that are able to deal with massive data: coarse grained parallelism and external memory. In contrast to previously known work for parallel setups, our method is able to fulfill the three criteria of uniformity, work-optimality and balance among the processors simultaneously. To guarantee the uniformity we investigate the matrix of communication requests between the processors. We show that its distribution is a generalization of the multivariate hypergeometric distribution and we give algorithms to sample it efficiently in the two settings.
perm.pdf (255.41 Ko) Télécharger le fichier
inria-00000900 , version 1 (02-12-2005)
inria-00000900 , version 2 (26-10-2006)
  • HAL Id : inria-00000900 , version 2
Jens Gustedt. Efficient Sampling of Random Permutations. Journal of Discrete Algorithms, 2008, 6 (1), pp.125-139. ⟨inria-00000900v2⟩
132 Consultations
1491 Téléchargements
