Separation of arterial pressure into solitary waves and windkessel flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
A simplified model of arterial blood pressure intended for use in model-based signal processing applications is presented. The main idea is to decompose the pressure into two components: a travelling wave describes the fast propagation phenomena predominating during the systolic phase and a windkessel flow represents the slow phenomena during the diastolic phase. Instead of decomposing the blood pressure pulse into a linear superposition of forward and backward harmonic waves, as in the linear wave theory, a nonlinear superposition of travelling waves matched to a reduced physical model of the pressure, is proposed. Very satisfactory experimental results are obtained by using forward waves, the N- soliton solutions of a Korteweg-de Vries equation in conjunction with a two-element windkessel model. The parameter identifiability in the practically important 3- soliton case is also studied. The proposed approach is briefly compared with the linear one and its possible clinical relevance is discussed.
Laleg_Crepeau-Sorine.pdf (188.67 Ko) Télécharger le fichier
inria-00000914 , version 1 (09-12-2005)
inria-00000914 , version 2 (30-03-2006)
  • HAL Id : inria-00000914 , version 2
Taous-Meriem Laleg, Emmanuelle Crépeau, Michel Sorine. Separation of arterial pressure into solitary waves and windkessel flow. MCBMS'06, Sep 2006, Reims, France. ⟨inria-00000914v2⟩
261 Consultations
662 Téléchargements
