Master-slave Tasking on Heterogeneous Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Pierre-François Dutot
In this paper, we consider the problem of scheduling independent identical tasks on heterogeneous processors where communication times and processing times are differ- ent. We assume that communication-computation overlap is possible for every processor, but only allow one send and one receive at a time. We propose an algorithm for chains of processors based on an iterative backward construction of the schedule, which is polynomial in the number of proces- sors and in the number of tasks. The complexity is O(np2 ) where n is the number of tasks and p the number of proces- sors. We prove this algorithm to be optimal with respect to the makespan. We extend this result to a special kind of tree called spider graphs.
d_ipdps03.pdf (96.6 Ko) Télécharger le fichier
inria-00001081 , version 1 (01-02-2006)
  • HAL Id : inria-00001081 , version 1
Pierre-François Dutot. Master-slave Tasking on Heterogeneous Processors. International Parallel and Distributed Processing Symposium, Apr 2003, Nice, France. ⟨inria-00001081⟩
210 Consultations
256 Téléchargements
