Extending the entry consistency model to enable efficient visualization for code-coupling grid applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper addresses the problem of efficient visualization of shared data within code coupling grid applications. These applications are structured as a set of distributed, autonomous, weakly-coupled codes. We focus on the case where the codes are able to interact using the abstraction of a shared data space. We propose an efficient visualization scheme by adapting the mechanisms used to maintain the data consistency. We introduce a new operation called relaxed read, as an extension to the entry consistency model. This operation can efficiently take place without locking, in parallel with write operations. We discuss the benefits and the constraints of the proposed approach.
AntCudMonCCGrid06.pdf (76.98 Ko) Télécharger le fichier
inria-00001140 , version 1 (06-03-2006)
  • HAL Id : inria-00001140 , version 1
Gabriel Antoniu, Loïc Cudennec, Sébastien Monnet. Extending the entry consistency model to enable efficient visualization for code-coupling grid applications. CCGrid 2006, May 2006, Singapore, Japan. pp.552-555. ⟨inria-00001140⟩
158 Consultations
137 Téléchargements
