Topological Quadrangulations of Closed Triangulated Surfaces using the Reeb Graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Graphical Models Année : 2003
Although surfaces are more and more often represented by dense triangulations, it can be useful to convert them to B-spline surface patches, lying on quadrangles. This paper presents a method for the construction of coarse topological quadrangulations of closed triangulated surfaces, based on Morse theory. In order to construct on the surface a quadrangulation of its canonical polygonal schema, we compute first a Reeb graph then a canonical set of generators embedded on the surface. Some results are shown on different surfaces.
hetroy-32.pdf (398.36 Ko) Télécharger le fichier
Format : Figure, Image
inria-00001143 , version 1 (09-11-2016)
  • HAL Id : inria-00001143 , version 1
Franck Hétroy, Dominique Attali. Topological Quadrangulations of Closed Triangulated Surfaces using the Reeb Graph. Graphical Models, 2003, Special issue: Discrete Topology and Geometry for Image and Object Representation, 65 (1-3), pp.131-148. ⟨inria-00001143⟩
197 Consultations
424 Téléchargements
