Homogenization of divergence-form operators with lower order terms in random media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Probability Theory and Related Fields Année : 2001
The probabilistic machinery (Central Limit Theorem, Feynman-Kac formula and Girsanov Theorem) is used to study the homogenization property for PDE with second-order partial differential operator in divergence-form whose coefficients are stationary, ergodic random fields. Furthermore, we use the theory of Dirichlet forms, so that the only conditions required on the coefficients are non degeneracy and boundedness.
lejay-homogenization-in-random-media.pdf (357.32 Ko) Télécharger le fichier
inria-00001220 , version 1 (09-04-2006)
Antoine Lejay. Homogenization of divergence-form operators with lower order terms in random media. Probability Theory and Related Fields, 2001, 120 (2), pp.255-276. ⟨10.1007/s004400100135⟩. ⟨inria-00001220⟩
143 Consultations
335 Téléchargements
