BSDE driven by Dirichlet process and semi-linear parabolic PDE. Application to homogenization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2002
Backward stochastic differential equations (BSDE) also gives the weak solution of a semi-linear system of parabolic PDEs with a second-order divergence-form partial differential operator and possibly discontinuous coefficients. This is proved here by approximation. After that, a homogenization result for such a system of semi-linear PDEs is proved using the weak convergence of the solution of the corresponding BSDEs in the S-topology.
lejay-BSDE-homogenization.pdf (450.58 Ko) Télécharger le fichier
inria-00001229 , version 1 (10-04-2006)
Antoine Lejay. BSDE driven by Dirichlet process and semi-linear parabolic PDE. Application to homogenization. Stochastic Processes and their Applications, 2002, 97 (1), pp.1-39. ⟨10.1016/S0304-4149(01)00124-7⟩. ⟨inria-00001229⟩
236 Consultations
199 Téléchargements
