Modeling and estimation of the cardiac electromechanical activity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We describe an approach that we propose to model the electromechanical behavior of the heart, and to use the model in a data assimilation procedure in order to perform an identification of the parameters and state. The modeling of the heart tissue is based on an electrically-activated contraction law formulated via multiscale considerations and is consistent with various physiological and thermomechanical key requirements. The global heart system also incorporates a simplified lumped modeling of the blood compartments. We report on numerical simulations and on validations of our model in reference and pathological conditions. Furthermore, the data assimilation procedure is intended to give access to quantities of interest for diagnosis purposes, and we present some promising results in this direction.
JSM-DC-RC-MS.pdf (881.92 Ko) Télécharger le fichier
inria-00001248 , version 1 (12-04-2006)
inria-00001248 , version 2 (19-05-2006)
  • HAL Id : inria-00001248 , version 2
Jacques Sainte-Marie, Dominique Chapelle, R. Cimrman, Michel Sorine. Modeling and estimation of the cardiac electromechanical activity. [Research Report] 2006. ⟨inria-00001248v2⟩
172 Consultations
647 Téléchargements
