An Adaptive Algorithm for constrained optimization problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Sana Ben Hamida
Marc Schoenauer
Several methods have been proposed for handling nonlinear constraints by evolutionary algorithms for numerical optimization problems. The most widely used are those based on penalty function, thanks to their simplicity. In this paper, we propose a new adaptative penalty approach for solving constrained optimization problems, based on the amount of feasible individuals in the population. This method uses specific selection and recombination operators adapted to the penalisation strategy. We demonstrate the power of this approach on the eleven test cases presented in the litterature.
ppsn2000.pdf (418.19 Ko) Télécharger le fichier
inria-00001273 , version 1 (27-11-2006)
  • HAL Id : inria-00001273 , version 1
Sana Ben Hamida, Marc Schoenauer. An Adaptive Algorithm for constrained optimization problems. PPSN 2000, Sep 2000, Paris, France. ⟨inria-00001273⟩
179 Consultations
235 Téléchargements
