On functions with a given fitness--distance relation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Recent work stresses the limitations of fitness distance correlation (FDC) as an indicator of landscape difficulty for genetic algorithms (GAs). Realizing that the fitness distance correlation (FDC) value cannot be reliably related to landscape difficulty, we investigate whether an interpretation of the whole correlation plot can yield reliable information about the behavior of the GA. Our approach is as follows. We present a generic method for constructing fitness functions which share the same fitness versus distance-to-optimum relation (FD relation). Special attention is given to FD relations which show no local optimum in the correlation plot, as is the case for the relation induced by Horn's longpath. We give an inventory of different types of GA behavior found within a class of fitness functions with a common correlation plot. We finally show that GA behavior can be very sensitive to small modifications of the fitness--distance relation.
FixedFDC99.pdf (88.33 Ko) Télécharger le fichier
inria-00001279 , version 1 (04-05-2006)
  • HAL Id : inria-00001279 , version 1
Leila Kallel, Bart Naudts, Marc Schoenauer. On functions with a given fitness--distance relation. CEC 1999, Jul 1999, Orlando, Fl, USA. ⟨inria-00001279⟩
121 Consultations
324 Téléchargements
