Dynamically-Fulfilled Application Constraints through Technical Services - Towards Flexible Component Deployments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We propose in this paper, a mechanism for Grid computing frameworks, for specifying environmental requirements that may set and be optimized by deployers. Specified by designers by parameterizing deployment abstractions, the constraints can be dynamically mapped onto the infrastructure. This work is integrated in the ProActive middleware with the concept of technical services. We illustrate this mechanism with a concrete use case: deploying a component-based application with fault-tolerance on an heterogeneous grid provided by the ProActive Peer-to-Peer infrastructure.
compframe2006.pdf (215.43 Ko) Télécharger le fichier
inria-00068595 , version 1 (12-05-2006)
  • HAL Id : inria-00068595 , version 1
Denis Caromel, Christian Delbé, Alexandre Di Costanzo, Matthieu Morel. Dynamically-Fulfilled Application Constraints through Technical Services - Towards Flexible Component Deployments. Proceedings of HPC-GECO/CompFrame 2006, HPC Grid programming Environments and COmponents - Component and Framework Technology in High-Performance and Scientific Computing, Jun 2006, Paris, France. ⟨inria-00068595⟩
175 Consultations
238 Téléchargements
