A Locating-First Approach for Scalable Overlay Multicast - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Recent proposals in multicast overlay construction have demonstrated the importance of exploiting underlying network topology. However, these topology-aware proposals often rely on incremental and periodic refinements to improve the system performance. These approaches are therefore neither scalable, as they induce high communication cost due to refinement overhead, nor efficient because long convergence time is necessary to obtain a stabilized structure. In this paper, we propose a highly scalable locating algorithm that gradually directs newcomers to their a set of their closest nodes without inducing high overhead. On the basis of this locating process, we build a robust and scalable topology-aware clustered hierarchical overlay scheme, called LCC. We conducted both simulations and PlanetLab experiments to evaluate the performance of LCC. Results show that the locating process entails modest resources in terms of time and bandwidth. Moreover, LCC demonstrates promising performance to support large scale multicast applications.
IWQos2006IEEE-FormatCamReady.pdf (471.25 Ko) Télécharger le fichier
inria-00069194 , version 1 (18-05-2006)
Mohamed Ali Kaafar, Thierry Turletti, Walid Dabbous. A Locating-First Approach for Scalable Overlay Multicast. IEEE IWQoS 2006, Jun 2006, Yale University, New Haven, USA., United States. ⟨inria-00069194⟩
83 Consultations
99 Téléchargements
