The Traffic Assignment Toolboxes of Scilab - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Elina Mancinelli
  • Fonction : Auteur
Jean-Pierre Quadrat
  • Fonction : Auteur
Laura Wynter
  • Fonction : Auteur
We present the two toolboxes of Scilab dedicated to the traffic assignment. The first one, called CiudadSim, is devoted to the single class single mode case. The second one, called MCiudadSim, is concerned with the multiclass multimode case. After recalling the notions of Wardrop equilibrium and stochastic assignments the toolboxes are introduced and the manuals --- describing completely all the functions --- are given.
Autre [cs.OH]
RT-0281.pdf (2.89 Mo) Télécharger le fichier
inria-00069897 , version 1 (19-05-2006)
  • HAL Id : inria-00069897 , version 1
Pablo Lotito, Elina Mancinelli, Jean-Pierre Quadrat, Laura Wynter. The Traffic Assignment Toolboxes of Scilab. RT-0281, INRIA. 2003, pp.87. ⟨inria-00069897⟩
144 Consultations
849 Téléchargements
