Camera calibration: estimation, validation and software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
The software tele2 3.1 allows, in particular, to measure the intrinsic parameters of a camera. Nevertheless, a single measure do not allow to characterize the distribution associated to a parameter. Moreover, if the way to obtain measures is incorrect, these measures may be outliers.Also, this document is made up of a method to measure the intrinsic parameters thanks to the software tele2 3.1, and to quantify the quality of the obtained values.An analysis of the experimental data is provided as well, allowing to validate the given method.
Autre [cs.OH]
RT-0258.pdf (1.02 Mo) Télécharger le fichier
inria-00069916 , version 1 (19-05-2006)
  • HAL Id : inria-00069916 , version 1
Matthieu Personnaz, Radu Horaud. Camera calibration: estimation, validation and software. [Research Report] RT-0258, INRIA. 2002, pp.48. ⟨inria-00069916⟩
189 Consultations
512 Téléchargements
