The Coq Proof Assistant : A Tutorial : Version 7.2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Coq is a proof assistant based on a higher-order logic. Coq allows to handle calculus mathematical assertions and to check mechanically proofs of these assertions. It helps to find formal proofs, and allows extraction of a certified program from the constructive proof of its formal specification. This document is a tutorial for the version V7.2 of Coq which is available from http://coq.inria.fr.
Autre [cs.OH]
RT-0256.pdf (249.45 Ko) Télécharger le fichier
inria-00069918 , version 1 (19-05-2006)
  • HAL Id : inria-00069918 , version 1
Gérard Huet, Gilles Kahn, Christine Paulin-Mohring. The Coq Proof Assistant : A Tutorial : Version 7.2. [Research Report] RT-0256, INRIA. 2002, pp.46. ⟨inria-00069918⟩
248 Consultations
224 Téléchargements
