The Coq Proof Assistant : Reference Manual : Version 7.2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
The Coq
  • Fonction : Auteur
Coq is a proof assistant based on a higher-order logic. Coq allows to handle calculus mathematical assertions and to check mechanically proofs of these assertions. It helps to find formal proofs, and allows extraction of a certified program from the constructive proof of its formal specification. This document is the reference manual for the version V7.2 of Coq which is available from http://coq.inria.fr.
Autre [cs.OH]
RT-0255.pdf (1.17 Mo) Télécharger le fichier
inria-00069919 , version 1 (19-05-2006)
  • HAL Id : inria-00069919 , version 1
The Coq. The Coq Proof Assistant : Reference Manual : Version 7.2. RT-0255, INRIA. 2002, pp.290. ⟨inria-00069919⟩
273 Consultations
1049 Téléchargements
