Solving Large Linear Optimization Problems with Scilab : Application to Multicommodity Problems
We show the incorporation into the Scilab environment of the codes Lipsol, Hopdm and Lp_solve. We describe their use from Scilab and give a comparison of some results obtained. Applications for multicommodity problems are shown, which are solved in a user-friendly way using Metanet for the data introduction and visualization of the results.
