The GDMO and GRM Modules Semantic Checker of the MODERES Java Toolkit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 1997
MODERES Java is an environment for the development of management information models. In its first release, it provides tools for the manipulation of information models specified using GDMO and GRM. This report presents one component of the environment, i.e. the GDMO/GRM modules semantic checker. The report contains a detailled description of performed verifications as well as a complete implementation and usage guide for the semantic checker as implemented within the environment.
Mots clés
Autre [cs.OH]
RT-0208.pdf (229.38 Ko) Télécharger le fichier
inria-00069963 , version 1 (19-05-2006)
  • HAL Id : inria-00069963 , version 1
Olivier Festor. The GDMO and GRM Modules Semantic Checker of the MODERES Java Toolkit. [Technical Report] RT-0208, INRIA. 1997, pp.17. ⟨inria-00069963⟩
128 Consultations
92 Téléchargements
