SCICOS A Dynamic System Builder and Simulator User's Guide - Version 1.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Scicos (Scilab Connected Object Simulator) is a Scilab package for modeling and simulation of hybrid dynamical systems. More specifically, Scicos is intended to be a simulation environment in which both continuous systems and discrete systems co-exist. Unlike many other existing hybrid system simulation softwares, Scicos has not been constructed by extension of a continuous simulator or of a discrete simulator; Scicos has been developed based on a formalism that considers both aspects from the beginning. Scicos includes a graphical editor which can be used to build complex models by interconnecting blocks which represent either predefined basic functions defined in Scicos libraries (palettes), or user defined functions. A large class of hybrid systems can be modeled and simulated this way.
Autre [cs.OH]
RT-0207.pdf (476.71 Ko) Télécharger le fichier
inria-00069964 , version 1 (19-05-2006)
  • HAL Id : inria-00069964 , version 1
Ramine Nikoukhah, Serge Steer. SCICOS A Dynamic System Builder and Simulator User's Guide - Version 1.0. [Research Report] RT-0207, INRIA. 1997, pp.80. ⟨inria-00069964⟩
187 Consultations
3108 Téléchargements
