MODE-FE: A GRM/GDMO Parser and its API : Release 1.0 Reference Manual - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 1996
Laurent Andrey
  • Fonction : Auteur
  • PersonId : 830887
MODE-FE (MODE Front-End) is part of the MODE (Managed Object Development Environment) prototype which is developed for integrating the use of Formal Description Techniques in an environment for building Management applications. MODE-FE provides a GRM (General Relationship Model) and GDMO (Guidelines for the Definition of Managed Objects) parser. The package offers specification checking and an Application Programming interface for manipulating loaded GDMO and GRM specifications. This document is the reference manual for release 1.0 of the MODE-FE (MODE Front-End) tool and its API.
Mots clés
Autre [cs.OH]
RT-0190.pdf (638.67 Ko) Télécharger le fichier
inria-00069981 , version 1 (19-05-2006)
  • HAL Id : inria-00069981 , version 1
Olivier Festor, Emmanuel Nataf, Laurent Andrey. MODE-FE: A GRM/GDMO Parser and its API : Release 1.0 Reference Manual. [Technical Report] RT-0190, INRIA. 1996, pp.115. ⟨inria-00069981⟩
147 Consultations
139 Téléchargements
