Distributed programming environments: an example of a message protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
Anne-Marie Dery
  • Fonction : Auteur
In this paper we present a message protocol used for message passing between external components and a distributed programming environment. These message protocol allows structured data transfer and remote operations as function calls or signal emission. In the distributed programming environment, a new component called a Message Manager handles the incoming messages and management. This message protocol has been implemented and validated in the {\sc centaur} system.
Autre [cs.OH]
RT-0165.pdf (113.73 Ko) Télécharger le fichier
inria-00070004 , version 1 (19-05-2006)
  • HAL Id : inria-00070004 , version 1
Anne-Marie Dery, Laurence Rideau. Distributed programming environments: an example of a message protocol. [Research Report] RT-0165, INRIA. 1994, pp.24. ⟨inria-00070004⟩
60 Consultations
68 Téléchargements
