Fluid dynamics computation with NSC2KE : an user-guide : release 1.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1994
Bijan Mohammadi
NSC2KE is a Finite-Volume Galerkin program computing 2D and axisymmetric flows on unstructured meshes. To solve the Euler part of the equations, a Roe, an Osher and a Kinetic solvers are available. To compute turbulent flows a $k-\varepsilon$ model is available. Near-wall turbulence is computed either by wall-laws or by a two-layer approach. Time dependant problems can also be considered as a fourth order Runge-Kutta solver has been used.
RT-0164.pdf (1.42 Mo) Télécharger le fichier
inria-00070005 , version 1 (19-05-2006)
  • HAL Id : inria-00070005 , version 1
Bijan Mohammadi. Fluid dynamics computation with NSC2KE : an user-guide : release 1.0. RT-0164, INRIA. 1994, pp.71. ⟨inria-00070005⟩
402 Consultations
773 Téléchargements
