Testing string superprimitivity in parallel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
A string w convers another string z if every symbol of z is within some occurrence of w in z. A string is called superprimitive if it is covered only by itself and quasiperiodic if it is covered by some shorter string. This paper presents an optimal [??] time CRCW-PRAM algorithm that tests if a string z is superprimitive, where [??] is the inverse of the Ackermann function. An alternative implementation takes [??] processors, and is the fastedt possible with this number of processors over a general alphabet.
Autre [cs.OH]
RT-0160.pdf (502.21 Ko) Télécharger le fichier
inria-00070009 , version 1 (19-05-2006)
  • HAL Id : inria-00070009 , version 1
Dany Breslauer. Testing string superprimitivity in parallel. [Research Report] RT-0160, INRIA. 1993, pp.8. ⟨inria-00070009⟩
88 Consultations
161 Téléchargements
