Factor Analysed Hidden Markov Models for Conditionally Heteroscedastic Financial Time Series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this article we develop a new approach within the framework of asset pricing models that incorporates two key features of the latent volatility: co-movement among conditionally heteroscedastic financial returns and switching between different unobservable regimes. By combining latent factor models with hidden Markov chain models (HMM) we derive a dynamical local model for segmentation and prediction of multivariate conditionally heteroscedastic financial time series. We concentrate, more precisely on situations where the factor variances are modeled by univariate GQARCH processes. The intuition behind our approach is the use a piece-wise multivariate and linear process - which we can also regard as a mixed-state dynamic linear system - for modeling the regime switches. In particular, we supposed that the observed series can be modeled using a time varying parameter model with the assumption that the evolution of these parameters is governed by a first-order hidden Markov process. The EM algorithm that we have developed for the maximum likelihood estimation, is based on a quasi-optimal switching Kalman filter approach combined with a Viterbi approximation which yield inferences about the unobservable path of the common factors, their variances and the latent variable of the state process. Extensive Monte Carlo simulations and preliminary experiments obtained with daily foreign exchange rate returns of eight currencies show promising results.
RR-5862.pdf (909.47 Ko) Télécharger le fichier
inria-00070164 , version 1 (19-05-2006)
  • HAL Id : inria-00070164 , version 1
  • PRODINRA : 250252
Christian Lavergne, Mohamed Saidane. Factor Analysed Hidden Markov Models for Conditionally Heteroscedastic Financial Time Series. [Research Report] RR-5862, INRIA. 2006, pp.48. ⟨inria-00070164⟩
251 Consultations
398 Téléchargements
