Control with transverse functions and a single generator of underactuated mechanical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The control of a class of underactuated mechanical systems on Lie groups is addressed, with the objective of stabilizing, in a practical sense, any (possibly non-admissible) reference trajectory in the configuration space. The present control design method extends a previous result by the authors to systems underactuated by more than one control. For example, it allows to address the case of a 3D-rigid body immersed in a perfect fluid with only three control inputs. The choice of the control parameters is also discussed in relation to the system's zero-dynamics.
Autre [cs.OH]
RR-5847.pdf (228.8 Ko) Télécharger le fichier
inria-00070179 , version 1 (19-05-2006)
  • HAL Id : inria-00070179 , version 1
Pascal Morin, Claude Samson. Control with transverse functions and a single generator of underactuated mechanical systems. [Research Report] RR-5847, INRIA. 2006, pp.20. ⟨inria-00070179⟩
49 Consultations
159 Téléchargements
