s'authentifier
version française rss feed
inria-00070182, version 1
Feedback stabilization for a chemostat with delayed output
Gonzalo Robledo 1
N° RR-5844 (2006)
Résumé : In this paper we consider a problem of asymptotic stabilization for a chemostat, by using a feedback control law and considering a delay $\tau>0$ on its output. The presence of these delays on the outputs makes more difficult to achieve our asymptotic stabilization objectives. We build a family of feedback control laws (using the dilution rate as control variable) obtaining sufficient conditions for asymptotic stabilization, given by upper bounds for the delay (which are dependent of the feedback control law). Using some reduction techniques we show that the control problem becomes equivalent to obtain global stability conditions for the zero solution of the scalar differential delay equation: $$ \dotu(t)=-G(u(t))+F(u(t-\tau)). $$
  • Domaine : Informatique/Autre
  • Mots-clés : CHEMOSTAT – FEEDBACK CONTROL – DIFFERENTIAL DELAY EQUATIONS
  • Référence interne : RR-5844
  • inria-00070182, version 1
  • oai:hal.inria.fr:inria-00070182
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 19:23:06
  • Dernière modification le : Mardi 4 Novembre 2008, 17:01:51
tous les articles de la base du CCSd...
